Any recommendation for a $1K TV?
Discussion in 'Archived Threads 2001-2004' started by Luc, Jul 15, 2002.
  1. Luc
    Luc Stunt Coordinator
    Sep 6, 1999
    227
    I have a 43RPTV as my main and looking get a secondary tv for my room to replace a really old one. I'm looking to spend about 1,000-1,300. Size > 25in? Flexible on that.
    Any recommendations? Wega the way to go?
  2. Thomas_P
    Thomas_P Agent
    Jun 13, 2002
    36
    You can't go wrong with a Wega. You can go a lot bigger than 25 with that budget. A good starter would be the 27fv300, for 750 i think. The 32 incher is about 1100. You could even go with a HD Wega within your budget. Definitely the 32HS20 and maybe the 32 HS500.
  3. BobJ
    BobJ Stunt Coordinator
    May 6, 2002
    178
    Check out the new Samsungs if you want HDTV. The 27" starts at $800
  4. JonDimasi
    JonDimasi Auditioning
    Jul 15, 2002
    10
    if you have 1000-1300 zenith has a 27in flat hdtv monitor for 800, and hitachi has a 32 in non flat for the 1000, however what i would truely recommend isnt out yet, panasonic had a ct32hx41 flat hdtv out for 1500 36 at 2000, the new model is out which is the hx 42 but they only released the 36 so far, if and when the 32 in replacement comes out it is fair to say it might be around 1300, as steal as far as im concerned
