Any problems using CAS 2 and CAS 3 memory together?
Discussion in 'Archived Threads 2001-2004' started by Jeff Lehr, Jun 13, 2002.
  1. Jeff Lehr
    Jeff Lehr Stunt Coordinator
    Jun 30, 1997
    59
    If I use 2 sticks of ram together, one with CAS latency 2 and the other with CAS latency 3, will it cause any problems as far as performance or system stability?
    Just wondering if I can get by with mixing these.
    Thanks.
    JL
  2. Colin Dunn
    Colin Dunn Supporting Actor
    Oct 10, 1998
    731
    7
    110
    Colin Dunn
    If you mix them, you'll have to run your system at CAS 3 to ensure stability. That will reduce your memory throughput as compared to CAS 2.
    But I'd take 256-512MB of CAS 3 over 64-128MB of CAS 2 any day for overall system performance...
  3. Jeff Lehr
    Jun 30, 1997
    59
    I assume this is set in the bios?
    JL
  4. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    Usually the BIOS will automatically use the slowest memory timings after querying the DIMMs. Even then, you may get system stability problems because of weird electrical differences between the two DIMMs.
    Rule of thumb: Don't mix different makes/brands of RAM if at all possible.
  5. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    I'm running with 256Mb of CAS3 and 128Mb of CAS2 at home, and now I'm on XP its nice and stable; I believe any instability problems I had were ME related, not hardware.
  6. Scott McC.
    Scott McC. Stunt Coordinator
    Jun 14, 2002
    52
    ummm, guys, any kind of memory type (PC-2100, PC-2700, etc.) would help, and also the manufacturer, sometimes you can run CAS 3 rated RAM at CAS 2 if you are lucky, and yes, it is both automatically set, or if you prefer, manually set in the bios, try it and CAS 2 and run memtest 86 on it, if it shows up all clear, you can just keep running it at CAS 2, if it doesn't boot, or becomes unstable, or fail memtest, just run it at CAS 3, of course you could always just buy some new RAM...
