Any problem with SVS lying down on its side?
Discussion in 'Archived Threads 2001-2004' started by Lee Whitney, Aug 28, 2001.
  1. Lee Whitney
    Lee Whitney Auditioning
    Aug 23, 2001
    6
    I have tried it this way pointed into a corner about 6" away from the wall, and it seems to work just as well.
    No offense to the designers who did a great job on the sound, but man I did not want that huge thing sticking up in the middle of my room.
    I have designed the rest of the HT to be as hidden as possible (for ex, gutted the stock speakers in my Pioneer HDTV and inserted M&K S150THX center channel).
    If there is any problem with the svs on its side I'll put it right side up again.
    Lee
  2. Richard Greene
    Richard Greene Stunt Coordinator
    Mar 5, 2001
    148
    I tried that with my four foot tall DIY tube sub.
    My sub had no base like the SVS's do so this may not apply:
    The sound quality deteriorates if you fire a
    sub into a corner made of plasterboard and wood.
    Even "lining" the corner with two large and heavy
    concrete patio slabs did not solve the problem for me.
    In general sound quality is better if the sound does not
    have to bounce off a wall on the way to your ears.
    Just placing a subwoofer driver near a wall (within 6")
    is likely to cause problems that can best be heard with a slow sine wave sweep test tone. My own walls resonate at 18-20Hz. so I must keep my tube sub driver about 10"
    from the walls (in a corner) and I must use two vertical concrete slabs in the corner, one leaning against each wall, to control the loud resonance.
  3. MarkO
    MarkO Second Unit
    Feb 19, 1999
    309
    It might "rock and roll" on its side [​IMG]
    [Edited last by MarkO on August 28, 2001 at 06:26 PM]
  4. RobP
    RobP Stunt Coordinator
    Apr 4, 2001
    185
    Lee I had the same question and I forget either Ron or Tom had told me that I could lay it on the side if I had too.
    Rob
  5. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
  6. AVspec
    AVspec Supporting Actor
    Sep 7, 1998
    515
    South Eastern PA
    Mark
    Yes, I was told by Tom that I could try my twin 20-39's on there sides if I wanted as my ceiling is low in the corners as he noticed from my HT pictures on my web site. I did try it this way and they actually worked quite well but I liked the sound better with them standing up side-by-side in the corner. It does not hurt to experiment in your own room though to get the best sound.
    -Mark
    **** Digital Vortex ****
    The Digital Electronic Site
    www.digitalvortex.com
  7. SVS-Ron
    SVS-Ron Screenwriter
    Jun 2, 2001
    1,074
    Lee,
    Sure, no problem laying the sub down. Certainly you may experience some variation in sound but it should not be sigificant.
    As for the comment about "the huge thing in your room", well, let's just say the designer is off crying in the corner right now. ;^)
    That'd be me.
    Hey, large black cylinders are not for everyone I guess. But you know what they say... in the dark, who can tell?
    Still there's hope. Our first wood veneer SS subwoofer (this one in oak) is getting boxed for photos and press release work as we speak though so there is hope for "non-black-cylinder-lovers" yet.
    Well heeled ones anyway. They won't be cheap.
    Or small.
    Well, you can't have everything.
    Ron
    [Edited last by SVS-Ron on August 28, 2001 at 08:26 PM]
  8. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    The problem with subs (if indeed you can call it a problem) is that they have to be big in some direction. My new Paradigm Servo 15 is big, square and boxy and I would much prefer the SVS footprint and added height instead. Aside from that of course I love the sub, but still.
    But I guess it does indeed vary based on both preferences and room decor.
    /Kimmo
