Any PC software to control a HK via the serial port?
Discussion in 'Archived Threads 2001-2004' started by Jack_V, Dec 28, 2002.
  1. Jack_V
    Jack_V Extra
    Dec 15, 2002
    20
    Does anyone have HK serial codes, or a program to control the receiver via the RS232 port?
    I did some searches but came up empty.
  2. Dean Roddey
    Dean Roddey Agent
    Dec 16, 2001
    35
    My CQC product doesn't specifically have support for the HK. But, it has a generic driver that lets you describe the protocol in a text file and then uses that description to integrate the device into the system. You could control your HK and any other devices you might want to control, as well as IR and X-10, macros, network distributed control and monitoring, etc... Check it out. If you are interested, join the forums (link at the top of the main web page) and post a thread on it. I and others can help you with the job. It's not too difficult once you get your head wrapped around the big picture, then you can whip out support for many serial devices easily enough.
