Any Mac C-39 or Sunfiire Theater Grand owners?
Discussion in 'Archived Threads 2001-2004' started by Meaux, Oct 29, 2002.
  1. Meaux
    Meaux Stunt Coordinator
    May 27, 2001
    168
    I really would rather have a Mac, but the salesman suggested the Sunfire.
  2. chung_sotheby
    chung_sotheby Supporting Actor
    Apr 8, 2002
    857
    Depends completely on what your listening preferences are. The Mac and the Sunfire are totally different beasts. The Mac is only 2 channel, and probably doesnt come with a remote, while the sunfire is a ht pre/pro. If you only want a pre for 2 channel listening, go and do a test between the two instead of being overly swayed by the salesman, as he probably makes a bigger commission on the Sunfire than the Mcintosh.
  3. Alex F.
    Alex F. Second Unit
    Aug 29, 1999
    377
    The McIntosh C-39 is a stereo and Dolby Pro-Logic preamp, and was discontinued in 1998.
    McIntosh's current home-theater pre-pro, assuming that's what you're looking for, is the MX-134, which retails for $7000. Its predecessor, the MX-132, which does not have the latest surround formats and various other features, may be still available in some stores at a close-out price. Check out mcintoshlabs.com's "Support" section for detailed info about both units.
    Happy listening!
