MarcianoD
Grip
- Sep 23, 2003
Ok I am looking to upgrade a bit maybe, I def want to do some things to make it look a bit better.
Right now I have the following.
Phillips 60 Inch HDTV
Sony 700 watt 5.1 surround sound
Sony dvd progressive scan dvd
I just bought a new speaker set By Sony the Extended Response 535 Model.
Now I am not all that satisfied with my phillips, I have to adjust the multipoints weekly. I have sent it back once already because the tv picture started to get offset on an angle. I am thinking of moving my phillips downstairs and getting a new dlp.
upstairs living room as best as I can. I also want to upgrade to a 7.1 surround sound. NOw I also want a central control in two rooms that I can run from one reciever/dvd Does anyone know of a place I can purchase these items from for the central control.
and what are you views of dlp. The only negative thing I have heard of, is the black levels.
Thanks for your help.
Money is not really an object I dont want to spend more than 2500k though, not including the tv.
