Any good suggestions???
Discussion in 'Archived Threads 2001-2004' started by Joe Tilley, Aug 25, 2002.
  1. Joe Tilley
    Joe Tilley Supporting Actor
    Jan 1, 2002
    686
    I need some suggestions for something. I work at Meijer's & have gotten the go ahead to set up a display to demonstrate the difference between P&S & WIDESCREEN. First off I will be useing two TV's of the same brand & size, Also two DVD players of the same brand. The only thing different is the fact one set up will be playing a P&S movie wile the other will be playing the same movie in WIDESCREEN to show the difference between the two.
    Ok so hers what I need. I need to come up with something crafty to actually explain what they are looking at. It will need to be something short & sweet that people will easily understand. I will be putting this on a small piece of poster board next to the TV displays. I have thought of a few different things to do but I thought maybe someone here would have a better suggestion.
    Hay ya gotta think its pretty cool when a store like this lets you do something like this. It is just one store but hay its a start, if it some how actually helped there DVD sales it could possibly get done at more stores. Meijer is another store that buys P&S movies first & only gets the OAR versions if P&S is not ava, Ya never know maybe it could catch on & they would buy more OAR movies instead if this works out.
    Thanks for any help & suggestions.
  2. TyC
    TyC Stunt Coordinator
    Nov 4, 2001
    184
    "Original Theatrical Presentation" and "Cropped Presentation"
  3. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    since you should probably stay family friendly with your dvd choices, I suggest using The Neverending Story.
  4. David Lambert
    David Lambert Executive Producer
    Aug 3, 2001
    11,380
    38
    In my signature is a squarish green link to the Widescreen Advocate site (the "No OAR = No $ale" thing). Look at their downloadable materials and see what you can use in-store!
