Okay, consider this sentence:
Everything that’s not electrical is considered low voltage and can use the open boxes, a bare frame, or even a hole through the wall, with the plate screwed directly to the sheetrock.
I know that if you mention the first item, “open boxes,” in a subsequent sentence, you refer to it as “the former.” The last item, “hole in wall with plate” is “the latter.”
The question: What is the term for the one in the middle? “Medial?” “Median?” I saw it done in an article in the paper a few years ago, so I know there is a correct term, but I don’t remember what they used.
Anyone know?
Wayne A. Pflughaupt
Anyone know?
Wayne A. Pflughaupt
