Any experience with Energy Take Classic 5.1 ??? (1 Viewer)
dBennett
Dylan
Hey guys,
I'm wondering if anybody has owned or listen to the Energy Take Classic 5.1 speaker system?
It has good reviews on amazon, but I was hoping somebody here has had some experience.
Any help is greatly appreciated!
gene c
Bay area, Ca
Gene
It's been a while since I've heard them but I remember being pretty impressed with them. They are often recommended around here along with the Boston Acoustics CS-2310B. As with all small speaker/subwoofer packages the sub is the weak link. If you're going to use them in anything but a small room you might consider buying the 5 speakers seperately and getting a bigger sub from BIC, PartsExpress.com or the Energy S10.3. It goes down to 21 hz!
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
SmCaudata
