Any electronics that will survive an EMP blast?
Discussion in 'After Hours Lounge (Off Topic)' started by Nathan Eddy, Jan 24, 2006.
  1. Nathan Eddy
    Nathan Eddy Second Unit
    Jan 22, 2004
    262
    I was just curious, given that Iran wants to build and use one against us. Are there any communication devices (CBs, walkie-talkies, etc.) that would work in the event of an EMP (electromagnetic pulse) weapon attack?
  2. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    I'm subscribing to watch the fun [​IMG]
  3. Nathan Eddy
    Jan 22, 2004
    262
    Fun? I'm not sure I get what you're saying.
  4. Kirk Gunn
    Kirk Gunn Screenwriter
    Aug 16, 1999
    1,609
    I don't know many specifics, but I assume the DoD has investigated this matter thoroughly and has developed capable products.
    Hopefully they will allow me to post to HTF when the sh-t hits the fan !
  5. DaveF
    DaveF Moderator
    Mar 4, 2001
    18,255
    1,641
    9,110
    One Loudoun, Ashburn, VA
    David Fischer
    Properly shielded electronics should survive. And old-skool analog phone (push-button, no features) could be useful, assuming the POTS infra-structure lives.
  6. Jeff_CusBlues
    Jeff_CusBlues Supporting Actor
    Jun 19, 2004
    605
    I work at a large military contractor and just about every radio we build is designed and tested to survive and EMP pulse.
  7. Ray Chuang
    Ray Chuang Screenwriter
    Jan 26, 2002
    1,055
    110
    I think people should remember that for EMP to work really effectively you need to detonate a megaton-yield nuclear device about 200-400 miles above the ground in space. That was what happened during the Starfish Prime test in 1962 using a 1.4 MT nuclear warhead.
    It appears that the so-called EMP bombs that spread filaments of carbon fiber are not as effective as they first guessed, and a low-yield 20 kT nuclear warhead detonated in near space won't have much EMP effects, either.
  8. ChristopherDAC
    ChristopherDAC Producer
    Feb 18, 2004
    3,729
    Internal Iranian politics are strange enough, and the record of those countries which have actually built atomic weapons is placid enough [the Bomb seems to have a remarkable moderating effect on even the most unstable regimes], that one can hardly speculate what developments over there will lead to.
    That said, and remarking that Ray Chuang is quite right about the magnitude of the weapon and the arrnagement of the circumstances which turned out all the lights in Honolulu [but lit up the sky brighter than any streetlamp], quite a few things would survive. All kinds of older electronics would be mostly OK: the lights went out in Honololu because the voltage surge induced in the power lines tripped the circuit breakers, and it took hours to get the power plants restarted. The problem is semiconductor junctions, because the induced voltage on a micro-scale can push them past breakdown voltage, and then they're no good anymore; there is also the possibility that capacitors could be blown up, but that's a secondary issue. Fortunately, it is possible to build parallel junctions which will take up the shock. Most civilian equipment isn't built this way, but mil-spec semiconductors usually are.
    In fine, then, your vacuum-tube radio will work; anything which has only germanium diodes and transistors will probably be fine; and "hardened" electronics, and probably most things inside Faraday cages [conductive shields; many PCs have at least partial ones, to avoid interference problems] should be OK. Your iPod will be toast, and you'll have to reset all your circuit breakers.
    I could write all night about the effects of atomic weapons, but I don't think anyone wants to read that.
  9. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    It would be amusing to have this backfire on Iran such that all their electronic equipment went on the fritz.
  10. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
  11. Colton
    Colton Supporting Actor
    Jan 12, 2004
    795
    Maybe it's just me, but if a nuclear missile (EMP) hit my local area - electronics would be the last thing on my mind. I don't think I'll be wondering if my warranty to my Dolby 6.1 Surround Sound receiver is still valid.
    - Colton
  12. DaveMcS
    DaveMcS Second Unit
    Jan 30, 2001
    316
    usually takes one well placed EMP to take out my Level 3 Sentry Gun [​IMG]
    (oblique team fortress reference!)
  13. MarkHastings
    Jan 27, 2003
    12,013
    Remember that massive blackout in the NY area when the power grid went down? I was laughing my ass off when no one was able to use their cell phones. [​IMG]
  14. Colton
    Jan 12, 2004
    795
    Mark, I'm not sure I understand why their cell phones wouldn't work. Explain, please.
    - Colton
  15. mattCR
    mattCR Executive Producer
    Oct 5, 2005
    10,568
    421
    9,110
    Lee Summit, Missouri
    Matt
    Because the towers themselves would go offline.
  16. Ray Chuang
    Jan 26, 2002
    1,055
    110
    By the way, one of the reasons why the Soviets had huge SS-9 and SS-18 missiles was to detonate a 20 MT nuclear warhead about 300 miles up over the continental USA. At that yield, the EMP would have been strong enough to knock out all the electronics in a large section of the USA; for example, if you were to detonate that 20 MT warheard 300 miles above Chicago, IL you would probably knock out all the unprotected electronics in Illinois, Wisconsin, Michigan, Indiana, Iowa, the eastern parts of Minnesota and Missouri, the western part of Ohio, and western half of Kentucky, and the northwestern part of Tennessee.
  17. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    The outrage if that were to happen over Detroit during SuperBowl.
  18. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Ever see "Broken Arrow"? The underground 3MT explosion causing an EMP was hilariously stupid if you know how these things really work.
  19. MarkHastings
    Jan 27, 2003
    12,013
    That's what happened...Not to mention the 'hubs' (or whatever you call them) went down as well.
    It was scary, but funny at the same time. I've never seen so many people FREAKING out because they couldn't use their cell phones.
    It really doesn't give me much confidence that people will act in a calm manner if something REALLY major happens. [​IMG]
  20. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    It's curious that the telepaths weren't affected.
