Any differences between Toshiba 57HX83 and 57HX84? (1 Viewer)
Antonio_B
Hi guys,
I would like to know if there's any difference in picture quality.
In other words,is it worth paying a few hundreds dollars for choosing the "Toshiba 57 HX83" over the
"Toshiba 57 HX84"?
Thanks in advance!
Mike Boniferro
Do you have an opportunity to see them side by side? I have never seen them next to each other, but the HX83 used with Pegasus IV guns, which they dropped on the new cimema series (HX84), so conceivably the HX83 might look better. Try to do a side by side comparison though if possible.
Righ
