Any Denon 3802 users TiVo?
Discussion in 'Archived Threads 2001-2004' started by Mark Kreisberg, Aug 8, 2002.
  1. Mark Kreisberg
    Mark Kreisberg Auditioning
    May 17, 1999
    8
    Just got my 3802 and am quite pleased. I'd like to give the remote a try but need to control my TiVo and I didn't see a code for it. Any success stories out there?
    I may have to also ask this over at Remote Central.
  2. Michael Mathius
    Michael Mathius Screenwriter
    Nov 12, 2000
    1,144
    2
    110
    Mark:
    I have both units but I use my pronto to control both.
    You should also try tivocommunity.com.
    Good luck.
  3. TysonL
    TysonL Agent
    Dec 8, 2001
    44
    I ditched by Prontos and went with the MX500 when I got my Tivo. The tactile thumbpad is great.....and it contols all of my equipment including the 3802.
    Tyson
  4. Mark Kreisberg
    May 17, 1999
    8
    Ok, thanks for the input. If I have no luck with the Denon remote I'll look into either the MX500 or the Pronto.
  5. Henry_W
    Henry_W Stunt Coordinator
    May 7, 2002
    137
    The Denon Remote has effectively learned every command I have given it from other remotes. I simply try to put the commands on logical buttons - which is somewhat hard to do since only small portions of the Denon remote are intuitively placed - and go from there.
    Now a question for Denon - You put emphasis on the remote for TV/Sat capabilities but don't have a previous channel/recall button? Sometimes one has to wonder just who makes the budget cutting/design decisions. To be fair, they are in this business to make an amp/reciever (which I find well done) and are not as concerned about remote asthetics or (obviously) intelligable manuals....
