Jeff Kleist
- Dec 4, 1999
Finally, David Gerrold's most evil, delay and cliffhanger filled saga's 5th chapter is in the home stretch!
A Method For Madness is now scheduled for early 2003. I only have about
50,000-75,000 words to go. The work is going fine, as you'll see below.
A Method For Madness: I have now written over 150,000 words of the primary
narrative of the book. It looks like it could go as long as 350,000 words,
or even longer. That will make it the equivalent of four ordinary novels.
Plus I have also written over 40,000 words of the interstitial material --
these are the little excerpts that appear between the chapters of the book.
In A Method for Madness, the excerpts will be taken from The White Book, the
encyclopedia of the Chtorran ecology. The White Book will explain large
parts of the Chtorran ecology and will clear up some of the mysteries that
Jim has been trying to solve since book one, including why there was a
fourth worm in that first dome.
Coming any day to a bookstore near you should be Leaping to the Stars, the third and final part of the Dingilliad trilogy (Jumping off the Planet, and Bouncing off the Moon are the others), his attempt (pretty succesful) of a modern-day Heinlein Juvie
