Elbert Lee
- May 24, 2000
I am looking for a cheap/used receiver that can run stabel at a 4ohm load. I'm using a Pioneer 606 to drive 2 CLARK bass shakers and it's fairly good. There's a switch on the back of the Pioneer that allows the user to switch betwen 6 and 8ohms, but I can't help but wonder how far I can push it. Although it works perfectly 90% of the time, I do get the "overload" protection once in a while.
I have an AudioSource AMP3, which is stable down to 4ohms, but without an external pre-amp, there is no way to adjust the gain on the incoming voltage so my bass shakers are hardly effective. Overall effect is preferred with the Pioneer receiver, but for extended bass effects, the AudioSourse "feels more solid".
Elbert
Elbert
