Shawn C
- May 15, 2001
We have been watching the progress of our house being built and we are finding some "problems" with the framing that has been done this past week. I don't know if most of these are actually structural problems, but the quality and care of construction seem to be lacking to my eyes.
Are these really problems or am I being too picky?
Here is a link to the entire gallery:
http://runespyder.smugmug.com/gallery/268425
I will outline the major things directly below.
1. Wood beam that spans front of garage is too short and only rest on one 2x4. This seems to be the biggest problem that I saw.
Here is where you can see that it is too short:
http://runespyder.smugmug.com/photos/10609934-M.jpg
Here is where you can see that the 2x4's supporting the beam were cut too short:
http://runespyder.smugmug.com/photos/10609935-M.jpg
2. Beam that spans across the back of the garage. Again, 2x4's cut too short and shims are used to make up the gap. Is this a generally accepted practice? Shouldn't the support been cut closer to the right length?
http://runespyder.smugmug.com/photos/10609937-M.jpg
http://runespyder.smugmug.com/photos/10609938-M.jpg
3. Notches cut into studs in order to accomodate temporary bracing. Is this a generally accepted practice? Are these diagonals temporary or structural?
http://runespyder.smugmug.com/photos/10609939-M.jpg
http://runespyder.smugmug.com/photos/10609940-M.jpg
4. Wall is storage area, behind stairs, in basement changes from 2x6 studs to 2x4 studs for not apparent reason. Is it because 2x6s will not anymore because the realtionship between the concrete and the framing is not consistent?
http://runespyder.smugmug.com/photos/10609942-M.jpg
http://runespyder.smugmug.com/photos/10609943-M.jpg
5. Badly split 2x4 used in framing. One of the same 2x4s mentioned above is split badly, but was still used??
http://runespyder.smugmug.com/photos/10609944-M.jpg
http://runespyder.smugmug.com/photos/10609945-M.jpg
http://runespyder.smugmug.com/photos/10609946-M.jpg
6. Pressure on nail gun too high? Almost everywhere in the framing, almost every toenail the wood has been split by the use of a nailgun. There are also areas where nail have been driven too far into some wood and it has caused cracking. Is this going to cause problems in the future? Here is an example
http://runespyder.smugmug.com/photos/10609947-M.jpg
7. Forklift mars in some wood. Do these kind of defects in the wood cause problems with moisture over time? It looks like someone was careless with a forklift
http://runespyder.smugmug.com/photos/10609948-M.jpg
8. Compromised 2x4 in the stairwell wall leading to the basement. Why would anyone damage a 2x4 like this and just leave it? It appears a large chunk was taken out of the 2x4 when someone attempted to nail the stair stringer to the 2x4. Is this stringer adequately supported now??
http://runespyder.smugmug.com/photos/10609949-M.jpg
http://runespyder.smugmug.com/photos/10609950-M.jpg
http://runespyder.smugmug.com/photos/10609951-M.jpg
