Ricky T
- Oct 28, 1999
....and more marketing BS behind "doubling-down" capabilities.
There's a very interesting article on Dec. 2001 Hi-Fi News, called "The Weighting Game". The author claims distortion (THD) is a very good spec to rate amps, provided a weighting scheme like n^2/4 (suggested by Shorter and Wigan back in 1950) is used, instead of the current unweighted measurements. In the above formula, n is the harmonic number.
Having said that, THD is easy to reduce. Use a bit of global negative feed back, and all of a sudden youve got 0.0000001% THD at 100W.
The problem is global negative feedback, which is used in most amp designs is almost universally accepted to sound like crap.
The key to great solid-state amp design is to minimize distortion of every stage before global feedback is applied.
I sometimes wonder if guitar/keyboard amp designers have more fun, because there you're actually trying to work with the distortion, instead of always trying to stomp it out.
So the question is..are we measuring the right things?
In many cases, apparently not.
Larry
That's exactly what that article was about, even presenting strong evidence of correlation between measurements and subjective testing.
(Rated at, and I quote, "No more than 2%" THD @ 1 kHz.)
Well, there was a post here a while ago about research that had shown that THD below 2% is pretty much inaudible. I don't think THD correlates directly to musical enjoyment though - you have to dig deeper into the specifics of it - is it harmonically related or random? What's the spectrum of the distortion? And so on... I've enjoyed most tube amps I've heard more than most SS amps I've heard, even though objectively the SS amps are the better performers.
