Any affordable universal player in the near future?
Discussion in 'Archived Threads 2001-2004' started by Charlie B. Ch., Feb 11, 2003.
  1. Charlie B. Ch.
    Charlie B. Ch. Stunt Coordinator
    Jan 29, 2003
    81
    Hi, this is my first post. My Sony NS315 just died. I have a Cyberhome 500 as a backup. Is there going to be any affordable (less than $300) DVD player that can play both SACD and DVD-A released in the near future (3-4 months)? My receiver has only one set of 5.1 input connection and, I believe, that 5.1 music must be output only through the 5.1 analog connection due to copyright restriction. Thanks.
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,187
    44
    1,610
    Central FL
    Phil
    Pioneer announced one for $279 list. It will convert DSD to PCM though on SACD
  3. Phil A
    Phil A Producer
    Oct 1, 2000
    3,187
    44
    1,610
    Central FL
    Phil
  4. Phil A
    Phil A Producer
    Oct 1, 2000
    3,187
    44
    1,610
    Central FL
    Phil
    Charlie, welcome to the forum as well.
  5. Charlie B. Ch.
    Jan 29, 2003
    81
  6. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Charlie, in addition to the Pioneer '563A, Zenith will be releasing the DV-318 universal player for around $200 later this year. Currently, your lowest-cost option is the Pioneer Elite DV-45A, which retails for $500.
  7. Tom Lee
    Tom Lee Agent
    Oct 21, 2002
    32
    Why will this unit convert DSD to PCM?
  8. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Tom- Because it's cheap. [​IMG] The current 45a and 47ai do *not* convert DSD (SACD) to PCM. Both use a Sony chip.
  9. Christ Reynolds
    Christ Reynolds Producer
    May 6, 2002
    3,597
    CJ
  10. Devin U
    Devin U Second Unit
    Jun 23, 2002
    399
    Didnt Apex release one last year at about 300.00? I heard that the audio wasnt all that good from it.
  11. Justin Lane
    Justin Lane Cinematographer
    Jan 18, 2000
    2,149
  12. Justin Lane
    Jan 18, 2000
    2,149
  13. Christ Reynolds
    May 6, 2002
    3,597
    CJ
    thanks for the link justin, very informative. looks like if i am going to make the plunge for a combo player, it will have to be the dv-45 with the icbm. i dont mind spending the extra money, if i know its going to be done right the first time.
    CJ
  14. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    Get the Yamaha, when you factor in the ICBM, the extra cables and the chroma bug of puioneer your better off getting the yamaha, or waiting for the denon.
  15. Kevin C Brown
    Aug 3, 2000
    5,712
    The Yamaha tested poorly for noise in the S&V review. Might depend on how much audio vs video you're going to watch/listen to. BTW, also some very useful comments on the Pioneers in the latest Perfect Vision (hint: they really liked the video in spite of the chroma bug).
    Also, check out the "upgrade" for Pioneer players here:
    www.tweakaudio.com
    Also, there was some strangeness about the Yamaha's bass management noted here:
    http://www.hometheaterforum.com/htfo...ghlight=Yamaha
    But if you're going to use an ICBM anyway, probably doesn't matter. [​IMG]
  16. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Justin,
    Good points about the DSD-to-PCM conversion process, and I'm glad you included the diagram. One could also argue that you by converting to PCM, you are losing the benefits of the very high sampling rate of DSD (2.824 MHz), which is attributed to giving SACD a more "analog-like" sound. It's all tied into the simplicity of DSD.
    Devin,
    APEX released the AD-7701 universal player for $300 last year. It was a disaster based on all the reviews I read. As Justin said, it was pulled off the market rather quickly. I heard that it was due to all the performance issues, but I also read that there may have been licensing issues with respect to the high-resolution formats.
  17. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
    Would there be less degradation for PCM->DSD and using DSD DACs?
  18. John-Miles
    Nov 29, 2001
    1,216
    3
    110
    No there wouldn't no matter how you convert it you still have PCM in the end, sure a DSD DAC may do the conversion better, but it will never get better than PCM
    do you follow what i mean?
  19. Craig_Kg
    Feb 25, 2002
    768
    Not at all. If the DSD->PCM causes less degradation than DSD->PCM, then wouldn't that be an overall gain (better for SACD, slightly worse for DVD-A). This is in context with the cheap player that only has one set of DACs.
  20. Christ Reynolds
    May 6, 2002
    3,597
    CJ
