DerekSPL
Grip
- Jul 28, 2003
Hey guys,
this is my first post on this forum, I'll probably post a lot more in the future cuz it looks like this could be a valuable resource.
I just bought a pair of A/D/S M12 monitors from a family friend. They're in perfect condition, but I know very little about them.
These speakers are at least 15 years old, and due to A/D/S changing ownership a few times there's almost no info to be found about them.
I need to know if these are worth keeping, or if I should try to sell them. How much do you guys think is a fair price to ask? I got a specs sheet from an A/D/S representative and that's all I have to go on right now. Here are a few notes:
Impedance: 4 Ohms, nominal
Freq response: 34-22,000Hz
Drivers:
One 1" soft dome tweeter with proprietary copolymer dome. Wet wound, oxygen-free copper voice coil on Kapton former. High Gravity magnetic cooling fluid for efficient thermal transfer.
One 5.9" high compliance midrange with proprietary polymer cone and polymer-modified butyl rubber surround., etc etc.
Two 8.5" high compliance woofers with the same materials as stated above.
Crossovers:
200Hz and 2000Hz. High efficiency, LCR Linkwitz-Riley design with 24dB per octave slopes
Recommended amplifier power: 25 watts minimum, 250 watts maximum.
Enclosure type: Acoustic suspension with glass fiber damping.
Enclosure construction:
High density, sompressed wood with extensive internal bracing. Diffraction-corrected front baffle and flush driver mounting.
Grille: Acoustically transparent, frameless perforated steel, color coordinated with speaker finish.
What do you guys think?
Drivers:
Crossovers:
