Anthem AVM20 - separate sub levels by input?!
Discussion in 'AV Receivers' started by Paul Gere, Sep 8, 2004.
  1. Paul Gere
    Paul Gere Second Unit
    Sep 3, 1999
    282
    I've been playing with my Anthem AVM-20 (v.2.13) and searching around here and can't find the answer - hoping someone can jump in with a little help.
    Where in the setup menu can I (if I truly can) set up different sub levels for Cinema and/or Music -or- by source/device (CD vs. DVD)?? I know in Menu 4.0, I can set overall levels, but shouldn't I be able to vary the levels by either input source or mode?
    I thought for sure I could do this, but after pecking around in the menu screens, I can't seem to figure out how.
    THanks in advance for any tips!!
    -Paul
  2. Mark Dubeau
    Mark Dubeau Stunt Coordinator
    Oct 8, 2001
    65
    If you change the sub level while listening to an input, won't it remember that level the next time you come back to it? (i.e. it isn't in the menu anywhere, but it remembers the channel levels for each input)
  3. Paul Gere
    Sep 3, 1999
    282
    Mark - YES!!!
    you're right. Not in the menu, but in the manual. A detailed read last night found that the AVM20 "memorizes" speaker settings for each mode as adjusted by the front panel controls - for each input. Tested this tonight and solved my problem.
    THANKS!
