Anthem AVM-20 vs Pio 563A DAC for cd music?
Discussion in 'AV Receivers' started by DavidNighorn, Nov 7, 2003.
  1. DavidNighorn
    DavidNighorn Stunt Coordinator
    Jun 3, 2003
    112
    The subject says it all. Should I play my cd's through the multichannel inputs on the AVM or should I use the coax digital connection? It comes down to which DAC is better.
    The other consideration is useability. If I use the 6.1 inputs then I can program my pronto to have a 'listen to music' mode. If I use the digital input, then I have to have a 'listen to hi-rez music' and a 'listen to cd music' mode. The user (my wife) will have to think about what type of music she is listening too, partly robbing the benefit of having a combo player.
    Your input is greatly appreciated.
    David
  2. JimmyK
    JimmyK Second Unit
    Jun 21, 2002
    479
    12
    Jim
    My first thought was that the Anthem would have better DACs than the Pioneer.
    That said, I would suggest you try both ways and see if you can hear a difference. If not, then use the hookup option that is most convenient for you.
    I wasn't sure from reading your post, but I assume you know you must use the multichannel analog outputs on the Pioneer to listen to high rez DVD-A and SACD.
    Hope this is of some help.
    JimmyK
  3. DavidNighorn
    Jun 3, 2003
    112
    Well, the answer is........the $170 universal player! I played the same cd from this player using both inputs and the multichannel inputs had a much more expansive, realistic sound. Who'da thunk it?
    As a point of disclosure, I am not an audiophile and I am not trying to justify nearly imperceptible differences. The difference was clearly audible. Ah well, this makes programming the Pronto that much easier.
    David
