Anthem AVM 20 - Grey Screen problem
Discussion in 'AV Receivers' started by Paul Pan, Jan 29, 2004.
  1. Paul Pan
    Paul Pan Auditioning
    Feb 21, 2002
    8
    Hi -
    I've had an Anthem AVM 20 (V 1.12) for nearly 2 years now. So far I couldn't be happier with it. Just recently, I mated it with a MCA 50.
    All of the sudden, in the last week or so, its been behaving strangely. Nothing has changed in my system except the new MCA50 amp last month.
    While watching Digital Cable thru Time Warner, every so often it will seem to lose signal and my screen will go all gray. Also, the other night, my picture went to black and white only. Switching to a different source, then back rectifies the problem.
    Did a search on this forum and didn't see anything like this. Anyone else experience this problem (and find a solution/explanation)?
    Paul
  2. wayne p
    wayne p Stunt Coordinator
    Jun 16, 2002
    162
    You may want to check your connections. Perhaps a cable was loosened when you installed the new amp. I had a similar problem with a SVHS cable and the picture suddenly going black and white. Pushing the cable in tightly corrected the problem.
