Antenna to receive OTA HD recommendation
Discussion in 'Home Theater Projects' started by Ken Holmes, Jul 31, 2005.
  1. Ken Holmes
    Ken Holmes Stunt Coordinator
    Jul 11, 2003
    102
    A friend just purchased the Panasonic 37" Plasma HDTV (TH-37PX50U). Has the built in HD tuner and he is looking to get OTA HD here in Columbus, OH. I was wondering if anyone has recommendations for antennas for him to look into?
    Thanks for any input.
    Ken H
  2. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    www.antennaweb.org can help you see what you can get.
    www.titantv.com can give you local listings.
    If you are close enough to the transmitters to get a signal from a set-top antenna, the Zenith "Silver Sensor" is very popular over at www.avsforum.com. If you need a rooftop model, I recommend the Channel Master lineup. I'm using a CM4221A and I love it.
    OTA HDTV is very cool, particularly for football and other sporting events.
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i second everything philip said. [​IMG]
