Antenna for receiving HD broadcast off the air
Discussion in 'Displays' started by HoiT, Jul 16, 2004.
  1. HoiT
    HoiT Agent
    Jan 23, 2004
    45
    Hi there,
    Just bought a Toshiba TV that has a HD tuner built-in. Just curious, what sort of antenna does one need to receive off the air HD broadcast? Thanks!
    HoiT
  2. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
    Go to www.antennaweb.org to determine the specific type (i.e. sensitivity rating).
    If you are in an area where transmission towers are within 10 miles you will generally have no problems using an indoor antenna. One of the inexpensive popular ones is Radio Shack's double bowtie model. If you have drop outs and signal interference you'll want to mount an outdoor antenna. I went the outdoor route and am using a 22.00 Radio Shack UHF model.
  3. shankar
    shankar Stunt Coordinator
    Feb 4, 2001
    85
    If you are going indoors... You may want to give this Terk or sliver sensor a try. I have the silver sensor INDOOR in the basement !! and can pick up stations from 70 miles away if properly oriented.. I don't think the RS DBT is available anymore. Don't fall into the "specialized" HDTV antenna hype ...
  4. Cameron Yee
    May 9, 2002
    11,680
    648
    Since 2006
    Cameron Yee
