Antenna for OTA HD reception
Discussion in 'Playback Devices' started by Jerrold J, Jul 12, 2003.
  1. Jerrold J
    Jerrold J Auditioning
    Jun 24, 2003
    3
    I have a HD ready set with DirectTV.I have decided to add Hi-Def. I am going to purchase a Zenith 520 tuner. The dish is being replaced in a few days with the needed one.I have a large outdoor UHF/VHF/FM antenna in the attic for FM reception to my audio reciever.Can I use this antenna for local OTA HD stations as well?If so ,can I use 2/1 splitter.I was told by a salesperson in CC that I need an antenna made for HD signals but I've read otherwise.Thanks!
  2. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,719
    463
    You need an antenna that brings in UHF channels since that's where the vast majority of OTA HDTV is being broadcasted. The notion that you need a "HDTV" antenna is misleading, just make sure it'll receive UHF.
    Give the splitter a try, it can't hurt.
    Consult www.antennaweb.org to find out where you need to be orienting your antenna for the necessary reception based on your position relative to the broadcast towers.
  3. SeanA
    SeanA Second Unit
    Feb 16, 2003
    329
  4. Phil A
    Phil A Producer
    Oct 1, 2000
    3,172
    38
    Central FL
    Phil
    Depending on the splitter, you may lose varying amts. of signal. I normal 75 ohm 2-way splitter may cause a loss of about 3.5db. One can get a splitter that will separate TV and FM bands (it looks similar to a 2-way splitter except one of the splits indicates 'TV' and the other 'FM') and that typically results in about a much smaller signal loss.
  5. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    I agree with Patrick, except that in some areas, stations are telecasting their digital signals on VHF. Here in the DFW metroplex, our ABC stations telecasts both their NTSC and ATSC signals on (different) VHF channels.
  6. dan fritzen
    dan fritzen Second Unit
    Mar 19, 2001
    304
    Anyone know where to get a good outdoor antenna? Does radioshack still sell these?
  7. Lew Crippen
    May 19, 2002
    12,060
    Yes they do, Dan
