DanMU
- Dec 28, 2002
Eventually I'll probably set up a satellite dish and go HDTV but for now I'm using one or two antennas and feeding TV and FM signals to a TV, two SVHS VCRs, a computer (soon two) with TV/FM card (both computers) and a HT receiver. I'll be running antenna cable to two or three locations and splitting further from there to several components. Of course, signal degradation is a concern. I've heard that RG-6 is much better than RG-59 (which I now have), so I'll definitely use RG-6. Doing some research I see that there are different qualities of RG-6 available. Some cheaper stuff uses copper covered steel core, whereas some uses pure copper and you can even get silver core for a premium. I saw 500' of RG-6 at Home Depot selling for $38 and wonder if that would be OK. My runs will be around 50 feet, but then there's the splitting, mostly near the end of the run. My first (two-way) split will be after maybe 25 feet. I figure the Home Depot stuff is the cheapest grade, but don't know. I'll be running the cable from the antenna through a wall into my attic, splitting it there and then through ceilings and along molding to the equipment. Home Depot had black and white (they were out of the white when I was there), and I'd get white if I had a choice because it would look better in the house. Can anyone coach me on the basics? Thanks!
