MarkHastings
- Jan 27, 2003
I am moving into a condo by June and just realized that I may need to either run ethernet cables or go wireless.
To avoid running cables through the walls, I have a question on wireless. When I first looked at wireless, it seems like the only question was to go with either B or G, but now there are TONS of options to choose from - HELP!
The Details:
1) I have DSL and only one computer (a desktop). I currently have a Linksys 4 port router and would prefer to stay with this brand.
2) The router would stay next to my computer, so I wouldn't need a wireless connection there (so as to avoid buying a wireless card to install). The place where I'd need the wireless is my ReplayTV.
I can always just use the phone modem in the ReplayTV (and avoid the wireless completely), but using the ethernet allows me to download recorded shows to my PC (as well as uploading photos). Since the ReplayTV only has an ethernet port, I obviously can't buy a PCI Wireless card and install it (like with my PC), so the question is, how do I get the wireless to the ReplayTV? I assume there is a wireless station I can attach to it? What's do I look for?
The last question is my method. I assume it's best to have the router next to my PC and connect an ethernet cable direct to the PC and use the wireless for the ReplayTV - as opposed to putting the router by my ReplayTV and using the PC for the wireless connection?
Any recommendations on wireless routers and stations?
The Details:
