Ken Woodrow
- Feb 12, 2001
I can't believe I'm asking this question, but here goes: I cannot seem to get an input signal on my Behringer Feedback Destroyer (model 1100). I believe (?) I have everything hooked up correctly: Receiver sub out to Channel 1 In (using 1/4" RCA-to-male phono plug adaptor) and Channel 1 Out to the subwoofer, but I can't seem to get any input signal when playing CDs or DVDs with the sub engaged. None of the signal lights on the left side of the display show anything. I've been trying it with the BFD in "bypass" mode as recommended by others in this forum (green light blinking). Any idea what I'm doing wrong? I tried turning the volume up, but still no lights (or sound from the sub for that matter). I assume I am using the correct "in" and "out" jacks on the BFD -- the ones grouped on the left are channel 1 and the ones on the right are channel 2, correct? Also, I've set the input levels at -10db, which should be correct for consumer gear. Any ideas? Are there any other settings that need to be engaged or changed?
Confused,
Ken
Confused,
Ken
