Ok so the amps are connected to the receiver. What type of interconnects do they use? Also do you just use normal speaker wire from the amps to the speakers?
Just regular interconnects with RCA connectors on each end. Of course you can spend as much or as little as you like on these interconnects.
And yes, just regular speaker wire from the amp to the speakers.
Bruce
