Another newbie interconnect question
Discussion in 'Archived Threads 2001-2004' started by Scott Miller, Sep 13, 2001.
  1. Scott Miller
    Scott Miller Agent
    Sep 9, 2001
    28
    When hooking up a DVD with a 5.1 decoder to a digital ready receiver, can you use 3 sets of 2 cables or do you need 6 individual cables? All of the signals should be the same, right?
  2. Dennis Jacob
    Dennis Jacob Agent
    May 8, 2001
    29
    You need to double check what your plugging into. Most DVD players have a single digital output in either optical or coax. This would be preferred over 6 analog outputs. Some of the outputs you're looking at maybe video too.
  3. Kelly Payne
    Kelly Payne Agent
    Jun 30, 1997
    43
    10
    Dennis,
    I believe that Scott has to use the on-board decoder in his DVD player, thus he needs all the seperate cables (Until he upgrades his receiver).
    -Kelly
  4. Scott Miller
    Scott Miller Agent
    Sep 9, 2001
    28
    Dennis, my receiver is only "digital ready" so it doesn't have any optical or coax inputs, only the 6 analog audio. So, with the DVD I'm getting this weekend, the Sony DVP-NS400D, I have to use the 5.1 outputs.
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i've got the same setup you do scott. i run the 6 cables from the back of my dvd to my receiver. i just bought some rat-shack gold plated jobs.
    works great...until i upgrade my receiver!
    [​IMG]
    You step in the stream,
    But the water has moved on.
    This page is not here.
