another first theater setup... (1 Viewer)
Torkey
Kyle
Hey Everyone! This is my first post here, I stumbled across the site doing some research for the media room im trying to create. My question is, I'm currently in the middle of building a new home, and I'm trying to figure out If I need to have them do a prewire for surround and projector...I had originally thought yes, however our local media store introduced me to the Epson Ensemble last night, and I LOVE it. However, damn thing is EXPENSIVE @ 7000 + install for the 1080, and 5000 for the 720...I DEFINITELY want to go with a front projection setup, looking for maybe 100" screen in a 16x21 room. I mean, I love the epson and how clean and simple it is, and the fact that it means no surround sound speakers on the wall and a retractable screen is great. I just want to know if I would be happy with the 720...I dont use any blue ray or HD cable or anything (yet ;) and the setup would be mostly for DVDs. I mean would it be better/cheaper to piece a setup together on my own and leave the prewire in with the home? Or Is the 5k a reasonable price for what it is on the 720 ensemble? Thanks for any help guys, I have to make a decision QUICKLY because I have to let them know by Friday whether i want them to leave in the prewire (im not electrically saavy enough to do it myself w/out burning the house down lol)...The epson apparantley doesnt require it because its all run off one wire. I also have to factor in the differing installation costs between a pieced together setup and the ensemble. I AM on a budget, the 1080 ensemble is WAY too much lol. BUt theres not a specific dollar figure involved. Just need a decent setup for a decent price, but not bottom of the barrel
Also, a powered screen (wall/ceiling mounted) is a HUGE plus. Thanks for any help everyone, looking forward to exploring the forums more!!!
DigitalFilth
Jason Thrush
Panasonic PT-AE3000 Projector and Carada Film Screen. Do all the prewire you can now as in power and video to the projector and speaker wiring. I think since you are on this forum you would not be happy with the epson in the long run and you could do a whole lot better with the price they quoted you.
Torkey
Kyle
sweet deal thanks, ill look into it...i have definitely decided against the Epson..its just too expensive..its nice, but its outta my range for a while lol
Torkey
Kyle
Going to add on to my initial post as its for the same project. I have done research on the Panisonic Ae300 and decided to use this projector. Coming up in the next few days, I have to give a distance for them to run the power outlet in the ceiling to plug the projector in. I plan on going with a 100-103" screen. I get a distance of 13'1"-13'5" (16:9) using the projection calculator here. Panasonic PT-AE3000 Projection Calculator - Throw Distance and Screen Size , while the users manual gives me a distance of 9'10" to 19'4"...how do i figure this out?? Also, how far back from where the projector is mounted does the outlet need to be? maybe half a foot or so?
Torkey
Kyle
any one? Any help would be HUGELY appreciated. They've started framing and I need to get them the location of the outlet within the next couple days..thanks!
Robert_J
Mississippi
The projector can be anywhere between 9'10" to 19'4" and it will work fine. I would go by what is stated in the owner's manual.
For example, I'm running a Panasonic AE-900U on a 103" DIY screen. I haven't measured exactly but I'm about 21' from the screen.
And 6" back from the projector will give you more than enough room for cables. If it is 6" back from the mount then you may want to move it back a little more.
-Robert
chris.big.money
Chris Walter
Is the user manual the length it can accomplish without going out of focus? It sounds like the measurement you got was exactly for your screen size, and the one in the owners manual is for any size in focus. As for plugs, i usually see them about a half foot back, half foot left or right for projectors.
I think you made the right choice by not going with the Epson system, you'd be more satisfied with a less expensive one that you piece together yourself.
Torkey
Kyle
Awesome, thanks for the help guys..how are you liking your AE3000? From the reviews I've read, i'm really excited to get this up and going. In the manual it states that the closest is for "wide" and the max throw distance for "telephoto". What exactly do these mean? Also would there be any drawbacks for mounting it at the front of the range vs. the middle or back of the range? ie, being able to watch movies in different aspect ratios later or anything? Also, the closer to the screen, the better it would be with more and more ambient light, correct? Thanks for the help guys, greatly appreciated.
chris.big.money
Chris Walter
You should be fine anywhere within that distance that the user manual gave you. The picture will be fine for any aspect ratio. The 3000 has a memory-controlled zoom feature for watching movies in different aspect ratios, so you will get a perfect picture anywhere within that distance. I'm sure that there's drawbacks to having it closer and farther from the screen, but how much ambient light will be in the room? With a projector like this one, the less ambient light, the better the picture.
Torkey
Kyle
not very much ambient light, there is one window, which will have a black out curtain by it, its in a loft space 13'W by about 21' deep, there are stairs on the side opposite the window, but they dont overlook below, there is a wall there. The projector will mostly be used for movies, probably in the evening, and MAYBE video games every once in a while...so do you think it would be optimal to keep it maybe towards the front of the range (maybe 11' or so) so that if there is a little ambient light I could maybe get a stronger picture? Also, Does the screen need to be bigger than your desired image size. Or can I buy 100" diag screen for a 100" picture. Sorry for all the newbie questions guys, im out of my niche on this stuff.
Robert_J
Mississippi
My screen is 103" diagonal between the border edges and I use all 103" when viewing high def material.
Pic 1 shows the front wall. Ignore the subs everywhere, I was testing some things. Pic 2 is a close-up of the border. Pic 3 is the frame when I was making sure everything was level. At the time I took the pic, the border was being painted in the garage.
-Robert
chris.big.money
Chris Walter
The only thing that concerns me is that you calculated around 13' for a 100" screen. So i'm guessing that you should start at 13' because you know that will get you your optimal screen size. What the manual gave you, as far as i know, does not apply to specific screen sizes, it simply applies to what the projector is capable of producing within a decent brightness and focus.
If you buy (or build, if it is not out of the question) a 100" 16:9 screen, you will fill the entire thing with a 16:9 image. With a 4:3 image, you will have bars on the side, and with a 2.35:1 or 1.85:1 image, you will have bars on the top and bottom. Now i'm not sure if they explain this prominently in the manual, but the memory-controlled zoom feature will come in handy. When you set up your screen, you should set it up with 16:9 material. It should fit the screen exactly. Then, switch to 4:3 and use the zoom and focus on the projector to fit the screen vertically and save this as a preference/profile/something (directions should be in the manual), and do this same thing for the other aspect ratios. This way, when viewing other material besides 16:9, you will not have to re-zoom and re-focus every time, you simply let the projector do it for you based on what your settings are.
Torkey
Kyle
Thats pretty cool! I had read about that feature, I just wasnt certain what it really meant until I followed along with your explanation. Thanks for the explanation! I went to a house that is a same model of ours and did a mock up today with different screen sizes and positions using masking tape. We started at 120" just to see if we could pull it off...with a viewing distance of about 12' it just seemed a little too big. So we mocked up a 103" screen and it suits the room size and viewing distance almost perfectly I think. With the back of the couch at roughly 12' (thats where the woman likes it in the room haha), I was planning on putting the projector at about 13'5" which works out pretty consistently with the calculations. the house is also on the same street, and same side of the street as the house we're building, so i tested to see how much we can control the ambient light and we can definitely cut it down to almost nothing with the use of one black out curtain. Then another question arose haha....when looking at where to mount the projector, I read in the manual that it says the distance from the top of the screen to the center of the lens should be between 2 and 6 feet for 100" view. The ceilings are 8 feet on the second level, and the projector screen is one foot from the ceiling on our mock up. So that would put the projector hanging down 3 feet from an 8 foot ceiling......the manual states that you can tilt the projector up to 35 degrees safely...i can put it right up at the ceiling almost and just tilt it without affecting any picture quality, correct? PS thanks again for all the help guys...
chris.big.money
Chris Walter
Yes, you can tilt the projector without losing quality. However, I am not entirely sure on this, but the 3000 should have quite a bit of vertical shift. So instead of tilting the entire thing you should be able to shift the lens down to hit the screen dead on instead of on an angle. Although depending on how much it can shift, you might have to angle it. No picture quality will be lost though. Make sure you follow up with how everything works out! I want to know how this projector is in action as i have never used it before, i've only used the 2000.
Torkey
Kyle
Ill definitely be here updating. Im sure i'll be back with plenty more questions too lol. Im doing the walkthrough with the superintendant next week to go over the electrical layout...so im sure ill be on here with a floorplan and another "how should i lay out my speakers" post haha. Speaking of which, is there any electrical stuff im forgetting about that I should have them do before the drywall goes up? As of now, they are prewiring for 5.1 (im going to see if they'll add another 2 channels), and they are running conduit up the wall and through the ceiling to make it easier to pull wires for the projector..any thing im forgetting?
Robert_J
Mississippi
Don't let them use speaker wire for the sub. Run RG-6 so you can use a line-level signal. Better yet, run both RG-6 and speaker. That will allow you flexibility in choosing an active or passive sub. Run sub wires to multiple locations. Bass response is very dependent on location and room shape. You can't always tell the best spot for a sub until you are calibrating.
I had them run 3 separate 20 amp circuits just for may A/V equipment. 1 in the back of the room for most. 1 in the ceiling for the projector. Finally 1 in the front of the room for my sub amp. All 3 are on the same leg of the breaker box to keep ground loops to a minimum. Even with that I can kick my USPes into low voltage mode when I crank my Motley Crue DVD to ear bleeding levels.
-Robert
Torkey
Kyle
Thanks robert. After seeing what the room is going to be like, it looks like I may have to stick with a 5.1 surround for this setup. (the right side of the room is pretty open minus two small posts, indicated on diagram..are there speakers on maybe a floorstand I should use in this instance?) I dont really see where else to mount the speakers. here is a rough diagram, if you could, please advise where the speakers would be best placed. Sorry, its kind of rough, i did it on paint during class lol.
Torkey
Kyle
also, i went to circuit city today and bought this HDMI 700hd High Speed HDMI Cable , the 50ft one, for $100 bucks. Its dumb I know, but I wasnt positive if I was going to need it or not. Is this something I will use for my setup? It just seemed like a decent deal and If i ended up not needing it, i could sell it. Thanks guys!
chris.big.money
Chris Walter
Kyle, i apologize for not replying to this thread. I'm not sure if your HDMI cable question remains, but i will answer it anyway. Even though Monster is not a highly-regarded brand, it seems like you got a decent deal for a good cable. Monoprice/Blue Jeans probably has it cheaper, but since you already have it, you should keep it. It just depends how long your run is going to be. You might not need a full 50 ft. In that case, i would suggest selling it (if you haven't opened it) and buying a shorter one.
EDIT: Also, to fully answer the question, you will use this for your setup because you want any HD Video/Audio. Right now, HDMI is the only cable that can carry both, and very well i might add.
Latest posts
TheThrillisgone
