Another DOS-question ( this time on CD-ROM ! )
Discussion in 'Archived Threads 2001-2004' started by Rob FM, Nov 21, 2001.
  1. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    471
    R
    Hey guys, I finally got that DOS Version 6.22 I was looking for...and since I didn't ever wanna be caught without it again, I burned it onto a CD-ROM so it would (hopefully) last longer than my floppy copy.
    My question is:
    Why can't I boot from my CD-ROM into DOS, like I can from a floppy?
    (Using W2K, PII-500, 24x spinner)
    I was just trying this as an experiment, but it didn't work. Did I do something wrong, or this just not possible to do?
    Curious in Seattle,
    ~Rob
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Go into the BIOS setup on your PC when you boot-up. ("press F2 for Setup"... or something to that effect)
    Depending on your system, you can sometimes designate your boot order in there. Otherwise, I would just create a boot disk that will load your CDROM driver and boot your CD.
  3. RicP
    RicP Screenwriter
    Feb 29, 2000
    1,126
    Hey Dave,
    Where's the pea soup to go with your signature? [​IMG]
  4. Steven K
    Steven K Supporting Actor
    Jan 10, 2000
    830
    You might need to run MSCDEX.EXE which is a generic Microsoft CD-ROM driver.
    Ahh, the good old days of DOS... when you actually had control of your own system
  5. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    471
    R
    Hi guys, I set up my bios to boot first from the CD-ROM (just for this test) and it spins the CD-ROM, so I think it recognizes the player....and it is a newer machine in that I've booted and installed W2K-Pro, Win-98 from the CD-player.
    Maybe (I'm guessing here) when I DOS from a floppy, it has to load the files into RAM...and it has trouble doing that from the CD-ROM?!?
    Anyways, just wondering if any of you guys have ever sucessfully booted into DOS from a CD-ROM? If it's possible, I'll keep trying!
    Thanks for the suggestions,
    ~Rob
  6. Steven K
    Jan 10, 2000
    830
    Rob,
    Yes, when you boot from the Win2K CD, it should give you a few options. I believe they are:
    "Install Windows 2000 from CD"
    "Start computer with CD-ROM support"
    "Start computer without CD-ROM support"
    choosing the second option will boot you into DOS, as will the second option, only MSCDEX will not be run.
  7. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    Bootable CD-ROM's aren't that hard to do, but they aren't that easy either. [​IMG]
    If you want a bootable DOS CD-ROM you can do it fairly easily in some CD-burning programs like Nero. You need a bootable floppy and can then use that with Nero to create the bootable CD-ROM. A trial version of Nero can be downloaded from http://www.ahead.de
    For creating other types of bootable CD-ROM's it gets trickier. For instance, I created a Windows 2000 bootable with service pack 2 integrated into the install, ie when I install Win 2K it is already at service pack 2 level without need for installing SP2 separately - but I needed help on how to do it. I found it here:
    http://www.nu2.nu/bootcd/
  8. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    471
    R
    Thanks guys, I'll keep trying it (using these suggestions)
    [​IMG]
    ~Rob
