DeathStar1
- Dec 28, 2001
- Neil
I installed a download resume program, I beleive it was Gator, and rememebered that the thing had loads of spyware. After I was down, I immediatly removed it, downloaded Ad Aware, found I had 14 Spyware peices on my machine. I removed them, but it wouldn't let me remove four.
I looked at the file names, and saw one that was running in my Task Manager. I cancelled it, reran AdAware, and it let me remove the files. I had no reason to restart my computer, untill I had to install a new program. When I started it, my computer started up a bit slower, and this error message started to pop up
"GMT.EXE
"This Application failed to start because EGNESENGINE.dll was not found. Re-installing the application
may fix this problem"
Is this part of the Spyware that is still loading? My computer runs fine without it, so it apparently isn't an essential program. If anyone can help me get rid of this error message, it'd be most appreciate...
"GMT.EXE
