Another Attic Antenna question
Discussion in 'Archived Threads 2001-2004' started by GrantF, Jul 10, 2001.
  1. GrantF
    GrantF Auditioning
    Jan 27, 2000
    2
    I have just entered the world of HDTV. I purchased a Channel Master antenna and set it up in my living room since I couldn't wait for the guy to come fish a cable from my attic. I was getting between 75% and 92% for all 4 ATL area digital channels.
    Today, I got the cable fished from the attic and went up to install my antenna. At first I was getting no signal so I hooked an in-line amplifier. I'm now able to get 70% on Fox, 22% on ABC and nothing on the others.
    My antenna is feeding the amplifier that is running down to my basement where I have all of my cables coming. I then connect to the cable that runs to the outlet at the TV. From that outlet, I then run into the HDTV decoder.
    Any ideas why I got such better reception in my living room than in my attic?
    Thanks for your help,
    Grant
  2. Andrew V
    Andrew V Stunt Coordinator
    May 11, 2000
    197
    Welcome to the Wonderful Work of HD!!
    I had this Problem two when I first installed my Cable HD. It turned out that the In wall Cable and all the Splits really degrades the Signal strength. If it’s possible, I would run a direct wire (from the Antenna) straight into the STB. If you can’t run a direct Wire then try to get rid of some of the Splits. Let me know how it works out. I think it all boils down to: How Dedicated you are to HD? [​IMG]
    ~Andrew~
    ~Pronto Programmer~
    AIM SN: FFU Productions
    ICQ #: 21603991
    Home Theater Pictures [Updated: June 22]
    Equipment List | My Growing DVD Collection
  3. GrantF
    GrantF Auditioning
    Jan 27, 2000
    2
    Since this thing is all about learning from others, I'll share the resolution to my problem. After 2 nights of playing with this antenna in my (very hot) attic, I finally thought to check the back of my HD TV. Sure enough, I was hooking my antenna to Antenna A input which is supposed to be the cable and looking at Antenna B for a signal.
    When I hooked up to the correct input, 75%-90% on all 4 digital channels that I have available.
    And I can return the amplifier that I bought because it doesn't buy me anything!
    [​IMG]
