annoying "problem" with my outlaw 1050
Discussion in 'Archived Threads 2001-2004' started by Kevin Kloet, Dec 2, 2002.
  1. Kevin Kloet
    Kevin Kloet Agent
    Sep 25, 2000
    27
    Whenever i change my digital input or source, the surround mode changes.
    So I have to cycle through back to "natural" (which i enjoy the most) everytime I change my source.
    This seems outrageous to me, does every 1050 owner have to deal with this?
  2. Thomas J. Coyle III
    Thomas J. Coyle III Stunt Coordinator
    Jun 22, 1999
    106
    Kevin
    I think that you will get more of a response if you post your question on the Outlaw website in the Outlaw Saloon for the 1050 Receiver.
    TCIII
  3. John Di Lauro
    John Di Lauro Stunt Coordinator
    Aug 4, 2001
    52
    Kevin,
    This is strange. My 1050 "remembers" the mode which was last selected for each source (DVD, CD, etc.)
    For example, my DVD player is connected through "OPT1" and normally left in surround mode. My CD player is connected through "OPT2" and normally left in stereo mode. When I cycle through the various sources, all of these settings are preserved. Are you saying that your 1050 is not doing this?
  4. Kevin Kloet
    Kevin Kloet Agent
    Sep 25, 2000
    27
    yeah, that's pretty much what i'm saying.
    when i switch from my computer's optical output (opt 1) over to say, the cd player, which is on the regular CD in - i have to adjust the surround mode back to "natural". This happens both when i go from one to the other and when i go back.
    a minor annoyance, but an annoyance. strange that you don't have this problem.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Well, before sending him packing for the Outlaw site, you might want to give this board's many, many Outlaw owners a chance to answer the question. Jeez.
  6. John Di Lauro
    Aug 4, 2001
    52
    Kevin,
    I have found that when you change the input assigned to a source (OPT1, OPT2, etc.) the mode in that source will revert back to Prologic. Do you have 2 different external devices assigned to the same source (e.g. CD) and switch between them using the "Digital Select" button? If so, try assigning your computer to the "AUX" source with "OPT1" active, and leave your CD player assigned to "CD" with the analog inputs active. Hope this helps.
  7. Kevin Kloet
    Kevin Kloet Agent
    Sep 25, 2000
    27
    yea, that's what i'm doing.
    I suppose what you offered is a fix, or at least a workaround.
    Just suprised that the otherwise very well thought out reciever does this.
    Thanks for the response.
