Annoying DVD player problem!! (1 Viewer)
ArtV
Grip
Hi.
I have a Sony DVP-NS300 stand alone DVD player. On every DVD I play the whole screen seems to get lighter and darker all of the time.
It only does this when I am watching a DVD. I can noticibly see it better if I pause the DVD. The whole screen will be bright then it will dimm very noticibly.
I was wondering if this is a solvable problem with AV cables or something.
Mick Wright
Macrovision. Are you running the video signal through your vcr? It needs to go straight to your display device (or receiver). If your display device doesn't have any video inputs you can use an RF modulator available at Wal-Mart or Radio Shack.
ArtV
Grip
I'm running it through the VCR.
The reason I stopped using the RF Modulator is because it gave the screen horrible static lines.
Carl Johnson
Carl III
Rather than running DVD thru the VCR you should get a switch box so they can both be connected directly to the TV but one at a time.
tgroskop
