Hello fellow members,
Last night during the hi-def presentation of Poseidon, it appears I may have damaged my speakers. In the scene where the water bursts through the bridge, the speakers emitted loud "snapping" type sounds which repeated whenever the sound from the movie hit similar audio peaks. My speakers are ten years old so it is probably time to upgrade. These are Infinity Overture 3 speakers and apparently they don't make any parts for them anymore. So now it looks like I have to speed up my schedule of operation "replace speakers".
Since I have been out of the speaker technology for 10 years, I find that Infinity no longer makes what I would want in a speaker and therefore, I need help in finding suggestions as to what speaker I should give a listen to.
My requirements are then these:
1. My "theater" is in a fairly large room, and I listen to music quite a bit. I prefer a musical speaker, meaning, I audition speakers with music and buy based on the speaker that plays music best (classic rock, acoustic, and jazz). Therefore, movie sound is secondary. I feel whatever is best for music will also be adequate for movie sound. I listen to two channel as well as multi channel music.
2. Since I prefer a musical speaker, I prefer towers in the front, providing a full range frequency response of 30 Hz - 20000 mhz or better. I also will be putting these same towers in the back as rear speakers as I prefer having full range speakers all around, rather than satellite speakers for the rear.
3. My receiver, B&K AVR 517 S2 has amplifiers rated at 150 watts at 8 ohms.
4. My budget would be $500 to $1000 dollars a speaker. I would also need to get a center channel speaker matched to the towers.
5. I will be getting a sub and am leaning towards the SVS PB-12 Ultra.
6. I also have speakers on the wall as sides (7.1 config). While the need to replace these right now is small, if there are any suggestions for these as well, that would be welcomed as I would want all speakers to match if possible (sub is not critical to this desire of course)
Could you all provide suggestions as to what to audition based on what I wrote here? Your help would be greatly appreciated. Let me know if you need other info to provide solid recomendations. Thanks.
