Jorge UF
- Nov 16, 2002
This is in continuation of my other thread.
I started out with 5 amps, and people kept reccomending amps and now I have finally narrowed it down to 5. The office is now closed to other amp reccomendations and it will be one of these 5. I have ranked them in what I feel is their proper order, after reading reviews and possible good pairing with my klipsch rf7's.
1.Classe CAV 180 = 5 x 180. Possible Audiogon price $2600
PROS:
Has a smooth sound that will blend well with the RF7's. Known as a high end audio amp manufacturer. Great reviews.
Cons:
The most expensive of the group. Might not even be able to find one that hugs the 2k price range. 2nd lowest spec power in the group.
2. Bryston 9b sst or st = 5 x 120. Possible audiogon price $2200
PROS:
Known as a very detailed amplifier with extremely low noise. The best reviews out of the bunch. Balanced inputs. Could possibly be better than the classe. The 20 yr warranty is untouched by other manufacturers.
CONS:
The 2nd most expensive. Many comment on it being too bright for klipsch. Lowest spec'd power of the group.
3. Parasound Halo A52 = 5 x 125. Street price $2000
Pros:
The best looking of the group. Many klipsch owners comment on the great pairing of parasound and klipsch. Ultra 2 certified (if that counts for anything)
CONS:
Low spec'd power. Could be the lowest power of the group.
4. ATI 2005 = 5 x 200. Street price $1750
PROS:
Big powerful amp. Will be able to drive almost any speaker that I may upgrade to. Cheapest of the group. Balanced inputs
CONS:
Ugliest of the group(well its not that bad). Many also say it might be bright with klipsch, though no actual reviews of the two have said this.
5. Earthquake CineNova Grande 5 = 5 x 300. Street price $2000
Pros:
The biggest and heaviest of the group. Appears to be also the most powerful as well. Good reviews from a strong little following. Not bad looking in silver.
CONS:
No balanced inputs.
Well there they are. Its taken me a while to finally get a real top 5. So which would be the amp to choose considering the pros and cons and the fact that I want to stay under 2k? I would appreciate it if you could give your top 3 out of these amps. Thanks guys
PROS:
Cons:
PROS:
CONS:
Pros:
CONS:
PROS:
CONS:
Pros:
CONS:
No balanced inputs.
