This DVD set seems to be riddled with errors. E-mails to both places have gone unanswered so far and sites like TV Shows on DVD have not reported anything. Two DVD review sites have confirmed that their copies also have the same problems.
Other consumers have reported that other Cannell Production shows on DVD are also not up to par. Since I am not familiar with those negativities, they can be posted in this forum if so desired. But this is for Silk Stalkings: Complete Second Season.
The order of the episodes are not chronological and this is glaringly obvious when you watch the set. They may be in broadcast order.
The biggest concern (which seems very much like an error but no one has verified it) is on Disc 4's "Dead Weight." It runs 37 minutes whereas all others run 45-47 minutes. The second-to-last scene seems to be missing as the case ends abruptly with no resolution. Was this scene or scenes removed or accidently omitted???
Finally, and these are minor complaints so please do better QC for future sets. If you are going to censor body parts/areas (case in point: "Irreconcilable Differences") at least do it discreetly, not with a big oval blur! Make sure your episode summary matches the episode itself (case in point: "In Too Deep").
Thank You.
Thank You.
