Thik Nongyow
- Jun 3, 2002
Even though anamorphic enhancement improves the resolution of a widescreen film on a television screen, is the process expensive to put into a DVD?
I don't think a High Def transfer is needed at allWell, then you can argue with Obi. I'll take his word for it.
Joe
Just curious, what was the reason that The Abyss never got an anamorphic transfer. I could be wrong since I don't remember the exact details from when it was released but from what I'm reading here, it sounds like it should have been do-able.The Abyss was a relatively recent transfer that was very high quality. (It was the first THX-certified LD.) Someone would have had to pay for an entirely new transfer, and neither Lightstorm nor Fox was willing to do so. This was at a time when the relative merits of anamorphic transfer vs. downconversion artifacts were still being hotly debated. Today I suspect there wouldn't be an issue.
M.
It should be pointed out that the word "anamorphic" is really misleading when it comes to DVD, as it has no bearing whatsoever on the use of anamorphic lenses used in the filming and exhibition of theatrical releases.It may be slightly confusing, but it isn't misleading. In both cases the word describes the way the image is distorted. (Ana-morph is just the Greek word for shape ("morph") with an "alpha privitive" prefix, a bit like "moral" vs. "amoral". It carries the sense of "not normally shaped.") The mechanism for doing this (optical or electronic) is immaterial to the meaning of the word itself, and it doesn't inherently have anything to do with film. (A distorting mirror in a funhouse could be called anamorphic, and probably was, long before movies were invented.)
It is true that the two terms as used with regard to film and DVD have nothing to do with one another, but that doesn't make one of them misleading.
"anamorphic adjective: producing or having different magnification of the image in each of two perpendicular meridians -- used of an optical device or the image formed by one" - Merriam-Webster Unabridged On-Line
Joe
Also, non-anamorphic looks better on 4:3 sets, which account for the vast majority of DVD capable displays. It was true then and it's just as true now.I never heard that before. Does that mean that I should buy the non anamorphic disc instead of an anamorphic one if I have a choice for my 4:3 tv?
I never heard that before.It was an issue much discussed on HTF several years back. You hear less about it now because the downconversion capabilities of players have continued to improve so that the difference between native 4:3 and downconverted 4:3 has narrowed considerably. But if you saw the downconversion artifacts on, e.g., an early Toshiba player, you'd notice them right away.
M.
he likes this reformatting so much he says he prefers those transfers to the letterbox versions more accurately following the theatrical presentation of the film.This gets repeated all the time, and I challenge anyone to find any quote where Cameron makes this general assertion. If Cameron really believes this, why are all the DVD versions of his films in OAR only (at least on initial release; Fox's new kick for P&S alternatives is a studio marketing ploy)?
All of this goes back to one comment Cameron made about the LD versions of The Abyss, which was his first Super35 film. Cameron has acknowledged that the LD versions of the film -- all three of them -- were something of a learning process for how best to adapt Super35 for home video given the limitations of then-existing NTSC video. DVD, with its greater resolution, absence of video noise, and the option for 16:9 enhancement, substantially reduced those concerns.
M.
