Anamorphic DVDs On 4:3 TVs
Discussion in 'Archived Threads 2001-2004' started by David Von Pein, Oct 24, 2002.
  1. David Von Pein
    David Von Pein Producer
    Feb 4, 2002
    5,748
    10
    This question has no doubt been addressed somewhere within the database of HTF threads, but I've yet to see it. ....
    When viewing an Anamorphic DVD on a standard 4:3 television, how much better (if any) is the resolution when compared to its non-anamorphic counterpart?
    I believe I've heard it said that "Anamorphic is always better", no matter the TV being used. Is this the case?
    Along the same lines (but with audio this time): Will a 5.1 DD soundtrack sound ANY different (better?) than a 2.0 Surround track when played through a Dolby Pro-Logic receiver? I know DVDs with 5.1 tracks will automatically "dumb down" to 2.0 Surround when sent through a Pro-Logic system. But I'm thinking that the soundfield might still be slightly fuller, even though it's being dumbed-down. I know that probably 99% of HTF'ers own DD receivers. But I'm wondering if anyone out there still has a Pro-Logic decoder only?
  2. Ming Wang
    Ming Wang Agent
    Aug 13, 2002
    43
    if the non-anamorphic disk is in letter box format (so same aspect ratio), it has less resolution. but since the player needs to add black bars on top and bottom, it reduces the resolution before it sends the images to TV.
    I guess it ends up with about same resolution.
  3. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    The 5.1 track will be more accurate in the placement of sounds. Even the best ProLogic decoders suffer some amount of "channel bleed". The easiest way to demonstrate this is with dialogue. If you turn off all but the rear speakers, there will be no audible dialogue in the rears with a 5.1 mix (unless it's been deliberately placed there, which is rare). In a ProLogic system, you'll be able to make out the dialogue, even though it should be firmly anchored to the center channel.
    M.
  4. Dave H
    Dave H Producer
    Aug 13, 2000
    5,540
    177
  5. Justin Gates
    Justin Gates Agent
    Feb 26, 2001
    47
    The only way an anamorphic DVD can look better than a non-anamorphic DVD on a 4:3 display is if the display has a squeeze mode like on the Sony Wegas.
  6. David Von Pein
    Feb 4, 2002
    5,748
    10
    Therefore, what you're saying is: An anamorphic transfer is pretty much meaningless to a person who watches DVDs on a 4:3 TV with no squeeze capability? In fact, according to Michael (above), Anamorphic will look WORSE is many cases (due to the downconversion)! Holy cow! Not good!
    So, since the majority of individuals with DVD Players lack a Widescreen monitor, this must mean that Anamorphic is pretty much a moot feature. (Although I find it difficult to fathom that an Anamorphic disc will actually look worse than a non-A. on a 4x3.)
  7. Damin J Toell
    Damin J Toell Producer
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
  8. David Von Pein
    Feb 4, 2002
    5,748
    10
    As can be obviously deduced by my total Anamorphic Ignorance, I'm a complete dunce when it comes to some of these tech matters.
    I just noticed on my Panasonic DVD Player's Set-Up Menu Screen, there are 2 different 4x3 choices. Why is this?
    You have a choice between setting the player up for .....
    16:9;
    4:3 Pan and Scan;
    or 4:3 Letterbox.
    I have a 4:3 TV, and have it set at 4:3 Letterbox.
    Is this the optimum setting for 4x3 viewing?
    Thanks for your assistance. [​IMG]
  9. Damin J Toell
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
  10. David Von Pein
    Feb 4, 2002
    5,748
    10
    Damin.....Thank you. And thanks for that link. [​IMG]
    Gee....I've always thought the word "Anamorphic" indicated "Better", no matter the monitor size.
    So, let me ask another one....Does this mean that (since I view DVDs on a 4x3 TV) I should opt for non-A. discs over Anamorphic ones, when both versions are available? Isn't it generally felt that most post-1999 transfers are better than the 1997-1999 ones?
  11. Frederic_A
    Frederic_A Stunt Coordinator
    Oct 17, 2002
    111
    I guess one thing to consider is that if you ever get a new TV, chances are high that it while either have the '16:9' squeeze feature or be widescreen. Also, if you have a dvd-rom drive on your computer, you would profit from anamorphic due to the higher resolution of the monitor.
  12. Michael Reuben
    Feb 12, 1998
    21,763
    2
  13. Brian McHale
    Brian McHale Supporting Actor
    Dec 5, 1999
    514
    12
    Brian McHale
    Even before I got my 16x9 TV, I tried to stay away from non-anamorphic discs when possible. Why would I do this when I had a cheap 4x3 TV that couldn't take advantage of it? Because I knew I would one day get a 16x9 TV, and I wouldn't want to repurchase all those discs.
    Eventually (whether it's five years or 20 years) we're all going to have 16x9 TVs, so it just seems to make sense to go for anamorphic DVDs.
  14. Joseph Young
    Joseph Young Screenwriter
    Oct 30, 2001
    1,352
    Michael Reuben,
    Exactly. [​IMG][​IMG]
  15. DaViD Boulet
    DaViD Boulet Lead Actor
    Feb 24, 1999
    8,800
    3
    How is native 4x3 (full frame, like wizard of oz) material "worse" than anamorphic? It's not loosing any scan-lines and maximizing resolution in the 720 x 480 array?
  16. soop.spoon
    soop.spoon Supporting Actor
    Aug 24, 1998
    757
  17. Adam Lenhardt
    Adam Lenhardt Executive Producer
    Feb 16, 2001
    17,721
    2,191
    9,110
    Albany, NY
  18. Dave H
    Dave H Producer
    Aug 13, 2000
    5,540
    177
  19. Robert Dunnill
    Robert Dunnill Second Unit
    Jun 16, 2001
    375
  20. Kwang Suh
    Kwang Suh Supporting Actor
    Sep 4, 1999
    849
    I wouldn't freak out too hard about downconversion artifacts anymore. The newer players have excellent downconversion. So, buy a new player if you're concerned.
