ericanthonE
- Feb 21, 2004
Hi, i am moderately new to Home theater. I was wondering.
I have a pioneer elite PD-F27 300 disc changer with legato link conversion, bla, bla bla...
I have a(am getting a rotel 1067 or maybe an Anthem. If i run a digital connection, say a digital optic to the receiver, then it would not really matter the sound difference as far as the better elite model that i have, to say the lower end pioneer that is available at say crutchfield.
I thought that the audio processing mattered, but now i have been gathering that it would only matter if you have a digital connection? Which means that you are using the Receiver for processing
I always thought that it would process through the CD player/DVD player, and then be reprocessed to the receiver with a digital connection. But if i used a digital optic connection/coax it would not matter if it was a lousy DVD player or a nice one with more upper end audio processing.
Is the reason that high end CD/DVD players with audio chips exist is mainly/pretty much only for using with a analog connection.
Just some food for thought. I would like to know more about this, thanks.
For instance, i have a very old DVD player that is some wal-mart brand from way back in the day when they first came out with them about 5 years ago(or so) and the receiver would LITERALLY have to be pretty much at about 5db position on the volume range to sound even decently loud. Where as the pioneer elite hooked up to the same receiver(nad T773) would only have to be at say a volume range level of 30db to sound pretty much full and filled throughout the room. WOULD BE MORE THAN ADEQUATE. Both hooked up via. optic connection
I blamed this on the poor dvd player, but someone told me that if you were not using an analog connection, that it would not matter the sound processing of the unit????? Which i don't understand. THanks
