Analog vs. Digital SPL
Discussion in 'Archived Threads 2001-2004' started by DaveZee, Feb 2, 2002.
  1. DaveZee
    DaveZee Auditioning
    Jul 27, 2001
    10
    I read in a different thread that analog is recommended over digital SPL. I went to RS to get the analog but they only had the digital, model 33-2055 for $60. Supposedly the analog is much cheaper. Are the analogs still available, and if so should i just check another RS?
  2. Stefan A
    Stefan A Second Unit
    May 27, 2001
    397
    Yes, I think the analog is probably better. Call radio shacks to find out who has it. Maybe you can order it right from their web site.
  3. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Analog is easier to read, and is cheaper (a good combination in my mind).
    If your local RS doesn't have the analog one, you can ask them to order one for you. The cat number is 33-2050.
    You can also order it by going to the website, or calling 1-800-THE SHACK.
    http://www.radioshack.com/product.as...5Fid=33%2D2050
    -Vince
