Analog/PCM source question
Discussion in 'Archived Threads 2001-2004' started by Allen Longcor, Apr 5, 2002.
  1. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    547
    110
    I have a listening mode preference for for analog/PCM sources on my Onkyo 595. Does Analog include SACD? Will this setting affect SACD multichannel or 2 channel SACD listening? Or will it not affect it because SACD is something different. I'd like to know so I can change it when I listen to say TV or regular CD's. Thx.
  2. Allen Longcor
    Oct 21, 2001
    547
    110
    Does no one know? Does the analog preference setting affect SACD 2 or multichannel listening?
  3. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    You should be running your SACD player in complete analog bypass, so no mode on your receiver should be affecting anything if you want everything that SACD can offer.
    You mentioned in another thread you were running in direct mode. I'm not familiar with Onkyos, but be careful because with some receivers all that means is the tone controls are bypassed.
    DJ
  4. Allen Longcor
    Oct 21, 2001
    547
    110
    Ok well I think direct is the closest I have to analog bypass so I shall run it in that. Thx for the help
