Analog or Digital SPL Meter from the Shack? (1 Viewer)
Andy_Hamric
I'm debating whether to get the Analog or Digital Sound-Level meter from RadioShack. I'm thinking that you might be able to read an analog needle better than just numbers.
Any thoughts?
Rutgar
The short answer is, either will work for HT. I've used both. I find that I like the digital version better though. It's more accurate, and easier to read.
- Rutgar
Owen Bartley
Oh man, I was just about to do a search/post on the same topic. Looks like I have some more research to do. I hope its not too much to wade through... my copy of DVE is on the way!
JamesCB
Come on people!
I've read through the threads. Like I said: "The analog version is preferred."
The digital version will work, but the problem is in the accuracy available with a digital read out. You will only get 0.5 db readings. The analog meter is easier to read and produce more accurate readings.
Do what you want, but you'll always get opposing answers.
Good luck,
James
Owen Bartley
Thanks Brian, I've been paying close attention to that thread. I think what I'm going to do is just calibrate my sub by ear anyway, since I tend to like it a bit hot. I have a CD I made witn some low frequency tones and sweeps that I used for the initial setup, which I'll probably use to tweak this too. I guess it might be nice to start with it calibrated at reference though... I'll go from there.
Roy Van Nostrand
Roy Van Nostrand
I've been a digital user since 1996 ...and I do love this place!
The analog 'rounding' issue is a moot point.
BAMatter
