analog or digital audio connection from DVD player to receiver
Discussion in 'Beginners, General Questions' started by MichaelLGallo, Sep 30, 2003.
  1. MichaelLGallo
    MichaelLGallo Auditioning
    Sep 29, 2003
    4
    Just upgraded my receiver (Marantz SR-7300) and was given a DVD player (actually a combo VCR-DVD by Samsung). So now I have a choice between an analog or digital (coax or optical, but I think coax would be the right choice, no?) connection from the DVD side of the player to my receiver. Anyone have reasons why I would want to use the analog connection rather than the digital, or vice versa? If I had a bunch a cabling lying around I'd just use trial and error, but why not ask the experts?
    [​IMG]
    P.S. I'm only running two speakers and a sub right now, but that could change.
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    I would run digital, so that you can take advantage of the bass management offered by the Marantz. And the D/A converters in the Marantz may be of better quality, but who knows.
    Trial and error is always worth it!
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I would run a digital cable, I use that in my 5300, i still think it sounds a little better (different is probably a better term) than the DAC's in my NAD 521i. I would wager the DVD player isn't up to snuff, the receiver DAC's will probably be better, but it's not hard to switch back and forth and decide for yourself. Connect both to the same input, then switch with the A/D button and you can do a very easy comparison and decide for yourself.
    Since you have cables lying around try it.
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    The 7300 has good DACs, so I would use digital, preferably coaxial, with a decent quality cable.
  5. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,411
    312
    9,110
    Cees Alons
    Digital seems the best choice in this case. Coax or optical doesn't make much difference. Choose your pick.
    Cees
  6. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    Digital is digital. Coax cable is cheaper. When I bought a new Yamaha receiver I simply used 'half' a stereo RCA connector to try the digital connection...
    The difference between analog & digital is night and day.
  7. ColinM
    Dec 9, 2001
    2,050
    Digital coax should be specifically 75ohm, like a video cable.
  8. MichaelLGallo
    Sep 29, 2003
    4
    Thanks folks, I'm going with the digital coax.
  9. Brian.Huep
    Brian.Huep Agent
    Jul 25, 2003
    43
    Most dvd players still need to be hooked up with the analog to listen to music cd's FYI.
    On all the dvd players I have had, regular music cd's only play threw the analog outs. Anything digital will still play threw the digital outs, so there is no harm.
  10. Kevin G.
    Kevin G. Second Unit
    Sep 30, 2003
    403
    I RESEARCHED THE VALUE OF COAX OVER OPTICAL AND VICE-VERSA
    AND ENDED UP GOING W/OPTICAL, IT WAS A LITTLE MORE COSTLY
    BUT I WAS AMAZED AT THE QUALITY OF SOUND AND SEPARATION OVER ANALOG,
    JUST MY TWO CENTS
  11. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    Be careful if you connect both digital and analog audio outputs...
    I've heard that if the dvd player is set to digital out and you run the bitstream through the analog output, you can seriously damage your receiver/speakers etc.
    I would recommend one or the other. Not both.
    I believe that most new receivers will decode PCM from cd's anyway via digital connection. Mine does.
  12. ChrisWiggles
    Aug 19, 2002
    4,791
    Kevin: You are confusing a couple things here. Analog connections (which uses two coax wires), versus a digital coax connection (one coax wire, 75ohm), versus optical digital connection (optical fiber, toslink). The difference (or non-difference) between digital coax and optical is ridiculously small, if at all audible. Given that the "high-end" world likes to prefer digital coax over optical, AND moreso that any 75ohm coax will do just fine and is a lot cheaper, I say coax digital is the way to go, if anything just to save some $$. As for analog connections, you can't really adequately compare analog versus digital connection (either digital, coax or optical), because analog utilizes the DACs in the player, wile using a digital connection instead shifts the decoding responsibilities to the DACs in an outboard processor (like a receiver).
    So in hearing a differene, the difference was not between wires, or digital versus analog connections, but in the DACs. Hope that helps with your understanding of what's going on.
    [​IMG]
  13. JamesHl
    JamesHl Supporting Actor
    May 8, 2003
    813
  14. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
