Analog Modem Suggestions Needed
Discussion in 'Archived Threads 2001-2004' started by Glenn, Jan 18, 2003.
  1. Glenn
    Glenn Stunt Coordinator
    Oct 26, 1998
    229
    Hi,
    I am in the process of changing over to a new DSL provider. Hopefully I will not lose DSL for very long but in the meantime and for possible future us I would like to get an analog modem.
    Would the external USB modems work as good as an internal? Any recommendations for internal or external analog modems? I'm not looking to spend a lot because hopefully I won't be using the dial-up connection much at all.
    Glenn
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    honestly just grab the cheapest one you can find, currently the fcc doesn't allow analog dail-up modems to operate past 53k and I have never connected past 48k when I once upon a time had dailup. Therefore anything rated for 56k and is dirt cheap will work just fine, especially if it's use is only temporary.
  3. DonRoeber
    DonRoeber Screenwriter
    Feb 11, 2001
    1,849
    Buy a US Robotics Sportster external serial modem. I believe the current model is USR5686E. Should be a little less than $100. It'll always work, nomatter what. I've had my Sporster for years now.
  4. Glenn
    Oct 26, 1998
    229
    Hi,
    Thanks for the suggestions. I probably won't get the US Robotics due to it's high price and my hopefully very low use for a analog modem.
    Glenn
