Analog, digital, or both?
Discussion in 'Beginners, General Questions' started by Charlie S, Mar 13, 2004.
  1. Charlie S
    Charlie S Auditioning
    Mar 13, 2004
    I recently got a Pioneer SACD/DVD-A player and hooked it up using the analog outputs to my Denon 3803 receiver. Is there any reason to also hook up the digital connection? I'm assuming the analog are good for music/movies/etc.
    Charlie
  2. Ed Moxley
    Ed Moxley Cinematographer
    May 25, 2003
    2,701
    Eastern NC
    Ed
    I would hook up the digital too, for movies. You can use the analog for movies, but the digital sounds better.... IMHO.
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    You MUST use the analog outputs to get high-res audio from DVD-A/SACD.
    You can use either for other formats. Which you use will depend on the features in your DVD player (usually bass management, time alignment, crossover adjustments, ect) compared to your receiver (usually better, more adjustments). You should also listen set up both ways, as one set of DACs may be better than the other.
  4. Tod Golden
    Tod Golden Stunt Coordinator
    May 3, 2003
    82
    With my Pio VSX-810 I found that using the digital connection on the 563 provided better sound output.
    Tod
  5. Adam.Heckman
    Adam.Heckman Second Unit
    Dec 9, 2003
    322
    Depends on your reciever. If you feel the DD/DTS decoder in the pio is better sounding that the decoder in your reciever, then you have no call for the digital hook ups. However, they are right, your reciever will most definately have more adjustability. I own the 563a, and while it IS adjustable, I definately prefer my Denon for movie decoding.
    Take it easy.
  6. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    You won't be able to apply any DSP/DPL modes unless you connect a digital coax or toslink cable.
