An excellent sub cable 3ft or less?
Discussion in 'Archived Threads 2001-2004' started by Chuck Paskovics, Feb 8, 2003.
  1. Chuck Paskovics
    Chuck Paskovics Stunt Coordinator
    Feb 26, 2002
    98
    Any recommendations on a subwoofer cable that is 3ft or less? I really like the AR stuff, but it seems the shortest they have is 12ft. My amps are right above my receiver so I only need a very short cable.
    Any recommendations for a top quality short cable?
  2. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    Why not just use one side of a 3ft AR rca cable?
  3. Chuck Paskovics
    Feb 26, 2002
    98
    I always assumed they were the same...is this a correct assumption (rcs cable and sub cable)?
    And when you say 'one side', what do you mean.
    If they work the same then that is what I will do, just buy a 3' RCA cable.
  4. Sean Carter
    Sean Carter Stunt Coordinator
    Jun 24, 2002
    65
    I didn't mean a particular end. I just meant that when you usually buys rca cables, you get a left and right. Just use either the left or the right.
  5. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    You can also use a 75ohm composite video cable.
