amplifier
Discussion in 'Archived Threads 2001-2004' started by jeremiel, Jan 16, 2003.
  1. jeremiel
    jeremiel Auditioning
    Jan 12, 2003
    4
    I would need some help.
    I'm making my first setup.
    I have a plasma TV.
    I'm looking for an Amp.
    I'm a car stereo guy... and I don't knos mush about DTS, DTS ES, THX... etc.
    I like nakamishi, denon.
    my budget is $300 to $1200.
    Thank you for any help
  2. Barry_W
    Barry_W Auditioning
    Dec 29, 2002
    5
    I'm a home theater designer in NY. You should seriously consider the Yamaha line. We have used almost every brand out there. We keep coming back to the Yamaha. You should consider the RX-V2300 and the RX-V3300. They are incredible controllable with extended ir commands for just about every function imaginable. If you need more info and the extended ir codes email me at [email protected]
  3. jeremiel
    Jan 12, 2003
    4
    I will take a look at the Yamaha RX series..
    Thank you for the help.
    Jeremie
  4. Shaad
    Shaad Auditioning
    Jan 20, 2003
    There is no receiver like Denon's AVR-3802 & is priced very reasonable. AVR-3803 is even better & AVR-5803 is the best based on how much you want to spend.
    Visit the link
    http://www.usa.denon.com/catalog/products.asp?l=1
    Look under Discontinued Products Archive to get information for AVR-3802 & under Dolby Digital, DTS &THZ A/V Receivers for information on AVR-3803 and AVR-5803
    Good luck.
    Shaad
