Amplifier Ohms
Discussion in 'AV Receivers' started by mark-h, Jan 20, 2004.
  1. mark-h
    mark-h Extra
    Dec 28, 2003
    17
    10
    If the specs on an amp say 200W @8 ohm and 330W @ 4ohm Does that mean that it will not do 6ohm or do they just not list it?
    Mark
  2. Erik Farstad
    Erik Farstad Supporting Actor
    Jan 28, 2001
    560
    Mark, the amp will do 8, 6, 4, and even 2 ohm...so you'll be just fine. I assume it's because your speakers you have or plan on getting are rated at 6 ohm right? Either case, no worries buddy! [​IMG]
  3. MichaelDDD
    MichaelDDD Supporting Actor
    Sep 29, 2003
    616
    Mike
    I agree with Erik, except for the "2 Ohm" part. Just b/c an amp will perform just fine with a 4 ohm load doesn't mean it will run at ALL with a 2 ohm load. The amp has to specifically be rated to run at a 2 ohm load, else you risk frying it and anything connected to it.
    That said, any amp rated down to a 4 ohm load will have an easy time driving a 6 ohm load.
    AFA what kind of wattage you'd be getting...I would opine and say somewhere smack b/t 200 & 330. [​IMG]
  4. mark-h
    mark-h Extra
    Dec 28, 2003
    17
    10
    Thanks.
    The amp is a Rotel RMB 1095.
    I might be buying the amp to drive front(400W), surround sides(400W), and rear speakers(175W). I will probably get the 2 channel for the fronts(400W).
    I am also looking at the Parasound and Sunfire.
    Mark
  5. Erik Farstad
    Jan 28, 2001
    560
    LOL...it might do 2ohm but I should have said "maybe!" [​IMG] I said "even 2 ohm" meaning it "might" be ok rated that low...thanks for making that clarification Michael! [​IMG] I meant well, but my fingers typed the wrong words! :b
  6. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    If you get the Sunfire, it can handle a two ohm load on a time limited basis. [​IMG]
    DJ
  7. marc_manny
    marc_manny Stunt Coordinator
    Nov 25, 2003
    55
    Can the Denon 3803 handle a 4 ohm load?
    Marc
  8. Mike_Skeway
    Mike_Skeway Second Unit
    Jan 13, 2004
    265
    If it lists a rating for a 4 ohm load it will handle a 6 ohm load no problem. For that matter most amps / receivers will handle a 6 ohm load. More and more are being able to handle a 4 ohm load.
  9. MichaelDDD
    Sep 29, 2003
    616
    Mike
    Don't know about that. I know it's rated for 6-ohm speakers.
    Possibly if had say, just the main L/R that were 4 ohm, then the rest 8 or 6 ohms, maybe. But "maybe" isn't a definitive answer. [​IMG]
    Bump for you.
